Re: Farmall 656...value?
Posted by camshaftprelube on May 11, 2009 at 09:06:56 from (140.183.63.33):
In Reply to: Farmall 656...value? posted by camshaftprelube on May 11, 2009 at 04:56:52:
I don't think there is anything actually wrong with the 8N, the baler is too big, I think. Also, the baler is partially hydraulic. Frankly, I have no idea how he pulled it off. I don't know much about baling.
Physically working on the tractor is where I'm comfortable. I've got a mid-70's JD 830 split in half with the countershaft out in my shop right now.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
