Re: Farmall 656...value?
Posted by Andy Martin on May 11, 2009 at 11:14:48 from (199.197.2.142):
In Reply to: Re: Farmall 656...value? posted by camshaftprelube on May 11, 2009 at 09:06:56:
What kind of baler does he have?
An 8N ain't much punkin, even compared with an H.
I don't work on tractos much because I only have M's and H's and they just don't break down if you keep oil in them and don't overload them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
