Re: Removal of Clutch Housing from Transmission case on H
Posted by david g on May 12, 2009 at 06:41:19 from (216.203.121.248):
In Reply to: Removal of Clutch Housing from Transmission case on H posted by Farmall Bob09 on May 10, 2009 at 17:24:57:
It is easy if you put a nut on the threaded dowels and turn them out first. They are only threaded on one end. This seems to be a common thing on the Farmall.
I found it nearly impossible to pry apart without removing the dowels first.
