Farmall 140 not running well
Posted by seventy468 on May 12, 2009 at 08:41:13 from (192.158.61.140):
I have a Farmall 140 with a belly mower that we only use to mow. Recently the engine has started performing poorly. Mainly when the pto is engaged and I am mowing. It will start to putt/cutout and will eventually kill itself if I do not stop. I noticed that if I pull the choke it seems to run a lot better.. but still not great. Then yesterday.. even with choke pulled it dies. I believe after it cools I can fire it up again, but will eventually die again. I pulled the Marvel Schebler carb off and nothing looked broke and/or dirty. I plan to check ign. system this evening but was curious if anyone has run into this as well. Any thoughts would be greatly appreciated. Thanks
Seventy468@yahoo.com
