Re: CUB LoBoy 154 making trans fluid.
Posted by John M on May 12, 2009 at 17:26:00 from (209.213.22.170):
In Reply to: Re: CUB LoBoy 154 making trans fluid. posted by Jiles on May 12, 2009 at 15:36:12:
I still think you have a problem with the return hose from the pump, OR could the shifter be wore in just the right place to allow oil to sling out in that area while in second? Another thing, but I dought this, I guess it could be possible that engine oil is getting into it,but I dought that. Only other thing I can think of is are you filling it with the mower up or down.
