Re: CUB LoBoy 154 making trans fluid.
Posted by Jiles on May 12, 2009 at 15:36:12 from (208.252.179.28):
In Reply to: CUB LoBoy 154 making trans fluid. posted by evielboweviel on May 12, 2009 at 11:33:56:
Red Dave said: (quoted from post at 20:44:02 05/12/09) Did you let it sit out in the rain? I don't know about Cubs, but some tractors can leak rainwater into the transmission around the gearshift.
Check the drain to see if it is water or oil at the bottom of the transmission.
Never been out in weather, at least not in the 25 years I have owned it.
I just finished mowing 2 acres in low gear, no oil escaping, went to second gear and within 500 foot the oil was coming out.
Absolutely makes no sense and has got me baffeled.
I am prone to think it may be a "vent" problem but I cannot find any type vent.
