Re: CUB LoBoy 154 making trans fluid.
Posted by John M on May 13, 2009 at 03:03:01 from (209.213.22.170):
In Reply to: Re: CUB LoBoy 154 making trans fluid. posted by Jiles on May 12, 2009 at 21:14:56:
The return hose goes into the top of the cover the shifter is mounted to. If its cracked or the curved peice iscracked in just the right place(s), it could look like the oil is leaking around the shifter. Im just curious as to how you can see it coming from the shifter with all sheet metal on it?
