MTA hydraulic pump
Posted by Dave H (MI) on May 13, 2009 at 08:17:35 from (205.188.116.73):
Here is where I am at with getting the lift-all working on the MTA. I was working under the assumption that the front mounted hydraulic pump was operating, but when I hooked up my remote cylinder it did not operate it thru the live hydraulics. Where it spent the winter it would not be obvious but I believe the hydraulic fluid leaked significantly thru a hose fitting as there is fluid on the cement under the tractor where it now sits. My question is, since before I found out my reservoir was so low I was working the lift-all control back and forth, is it likely I have damaged the pump? It worked well last fall.
The leak is not a major short term issue and I can handle fixing it. At the moment I am just worried about my pump.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
