Re: MTA hydraulic pump
Posted by mkirsch on May 13, 2009 at 10:10:21 from (64.80.108.55):
In Reply to: MTA hydraulic pump posted by Dave H (MI) on May 13, 2009 at 08:17:35:
Good news!
To answer your question... As long as there is SOME fluid in the system, ANY fluid at all, you won't do damage to the pump. There's enough to lubricate the pump, which is what's important.
