Posted by '43h on May 13, 2009 at 10:14:57 from (70.105.74.203):
In Reply to: Re: h hand crank posted by HENRY E NC on May 12, 2009 at 21:05:59:
I had soaked everything I could reach from the bottom with WD-40, but I will try the PB blaster and keep doing it for a few days. The shaft at the handle does move a couple of degrees in each direction, but I doubt that the other end is moving at all. From the responses, it appears that using a lot of force, in combination with the PB Blaster, shouldn"t hurt anything(?) Thanks for the help and I"ll post the results.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
