Re: outer axle bearing on H sealed side in or out?
Posted by randy hall on May 13, 2009 at 15:05:23 from (216.201.25.70):
In Reply to: outer axle bearing on H sealed side in or out? posted by Brad in WI on May 13, 2009 at 14:27:06:
the shielded side goes in.
