outer axle bearing on H sealed side in or out?
Posted by Brad in WI on May 13, 2009 at 14:27:06 from (24.164.248.98):
when I tore my axle apart I forget to look at what way the single sealed side of the bearing was. Was it sealed to the inside or sealed to the outside. Thanks
