Re: CUB LoBoy 154 making trans fluid.
Posted by Jiles on May 13, 2009 at 16:59:29 from (208.252.179.28):
In Reply to: CUB LoBoy 154 making trans fluid. posted by Bob Kerr on May 12, 2009 at 11:33:56:
John M said: (quoted from post at 11:03:01 05/13/09) The return hose goes into the top of the cover the shifter is mounted to. If its cracked or the curved peice iscracked in just the right place(s), it could look like the oil is leaking around the shifter. Im just curious as to how you can see it coming from the shifter with all sheet metal on it?
I have removed the sheet metal and belt guard. The oil is definnately coming out the shift lever cover.
I have wiped it clean several times.
There is a plastic or hard rubber cap, similar to 1/2 of a tennis ball, and it moves with th shift lever. This is all about 8 or 10 inches higher then the oil level.
