CUB LoBoy 154 making trans fluid.
Posted by Jiles on May 12, 2009 at 11:33:56 from (208.252.179.27):
A few weeks back, I posted a problem with my Cub 154 leaking trans oil at the gear shift.
I have searched for the post but can't find it.
Before cutting season, last year, I changed ALL fluids as I have done during the 25 or so years I have owned it.
I cut my 3 acre yard all summer with no problems.
In my original post, I stated that oil would come out at the gearshift leaver cap and run down the housing.
All fluids were checked and all were at correct level.
My cub has three fluid check points at the rear of the tractor.
I can mow my yard in LOW GEAR and no fluid escapes.
In SECOND GEAR the fluid escapes.
I checked all fluids again today and the transmission was over full by about one cup. I figure about this same amount has leaked during use.
The other two checkpoints are at the correct level.
I know this seems impossible, however it is happening.
ANY SUGGESTIONS?
