Re: farmall 504 diesel sleeves story
Posted by the tractor vet on May 13, 2009 at 21:34:52 from (76.212.227.78):
In Reply to: farmall 504 diesel sleeves story posted by Todd Frampton on May 13, 2009 at 20:00:36:
The correct repair is to have the block bored with a boring bar and if it is bad then you install a repair sleeve and then bore that sleeve to take a std stock sleeve and they MUST BE A PRESS FIT our you will find it in the pan on a later date ' If you look at the deck of the block you will see letters by each hole and the letters are A,B,C,and D . A and B sleeves are one outside dia. and C and D sleeves are a nother and you NEVER install a A-B sleeve inmto a C-D bore class.
