Re: outer axle bearing on H sealed side in or out?
Posted by Owen Aaland on May 13, 2009 at 22:54:46 from (65.165.246.54):
In Reply to: outer axle bearing on H sealed side in or out? posted by rustred on May 13, 2009 at 20:27:45:
rustred said: (quoted from post at 20:27:45 05/13/09) the open side goes to the grease or oil, that should be easy to figure out and remember.same with your seals lip to the oil.
Ah... but not so easy to figure out in this case. The inside of the bearing is exposed to oil from the rear frame. The outside of the bearing is exposed to grease from the grease zerk. The shielded side goes in so that the grease can get into the bearing on the open side.
