Re: outer axle bearing on H sealed side in or out?
Posted by rustred on May 13, 2009 at 20:27:45 from (72.172.100.113):
In Reply to: outer axle bearing on H sealed side in or out? posted by Brad in WI on May 13, 2009 at 14:27:06:
the open side goes to the grease or oil, that should be easy to figure out and remember.same with your seals lip to the oil.
