Re: outer axle bearing on H sealed side in or out?
Posted by D Slater on May 14, 2009 at 04:17:07 from (72.65.132.3):
In Reply to: outer axle bearing on H sealed side in or out? posted by Brad in WI on May 13, 2009 at 14:27:06:
I go with Randy and Owen, The open side went toward the grease fitting on the axle cap or to outside. Later on IH started putting in bearings without a shield in other tractors and started selling them as replacements for earlier tractors. replacement axle caps were sold without grease zerk openings also.
