Re: farmall 504 diesel sleeves story
Posted by the tractor vet on May 14, 2009 at 06:56:41 from (76.212.227.78):
In Reply to: Re: farmall 504 diesel sleeves story posted by Pandra 504 on May 14, 2009 at 05:09:31:
Well as for the lack of stampings i can not say on yours , it could have had the deck milled at one time and nobody restamped And with out micing each hole then it turns into a craps shoot . Myself i prefer the press fitting as to the freezing and before any sleeve goes in a bore gauge is used to check the bore from top to bottom all around the bore then and only then is a sleeve selected . Same goes for the pistons as i check sizes on all pistons and compare to the bore and hand fit each one to the hole that it is going into But that is just me . If i have to deck a block then i stamp the deck with the amount taken off and if there are bore classes stamped into the deck i re stamp same goes for any of the heads that i had milled they were stamped with the amount removed now ah days nobody takes the time for this .
