Re: Need Basic Advice on Packings-F20 Regular
Posted by kevin LA-CA on May 14, 2009 at 20:13:59 from (173.51.84.53):
In Reply to: Need Basic Advice on Packings-F20 Regular posted by Loren in Iowa on May 14, 2009 at 19:06:29:
I gave up on the packings on my regular. I put in lip seals on both the PTO & belt pull. Worked pretty good.
Measured the ID of the housing & OD of shaft - bearing house found best ones. Then used silicone to seal the OD. Put a short length of pipe to clamp the seal with the packing nut.
I will see if I have the part numbers here.
kevin
