Need Basic Advice on Packings-F20 Regular
Posted by Loren in Iowa on May 14, 2009 at 19:06:29 from (207.177.2.187):
I need some basic advice on packings. The gear case input shaft on our Regular leaks. We replaced the packing, a while back, but not sure we did it right. We cut the packing in a "coil". Should we have cut "donuts" of packing, and staggered the splices, like you would stagger the gaps in a set of piston rings?
I've read about guys that replace the packing with a lip seal, or use one in additon to the packing. Has anyone got the number of the seal that works for this?
I've read guys that say that they should leak, because they are very old. I'm not real satisfied with that.
