Re: Mystery Starter Cranking
Posted by Bob M on May 15, 2009 at 09:54:01 from (151.190.254.108):
In Reply to: Re: Mystery Starter Cranking posted by karl f on May 15, 2009 at 08:26:25:
karl - The clutch safety switch is a good idea.
Carrying it a step further I'm contemplating adding a marine-rated battery disconnect switches in the battery ground cable on all my tractors.
Would effectively eliminate the possiblity of an accidental start. Also eliminates the chance of a fire from a short circuit while the tractor is parked.
Further it will deter at least the casual would-be tractor thieves...
