Re: 400 Diesel purge procedure
Posted by Bill46 on May 15, 2009 at 10:05:20 from (65.112.42.84):
In Reply to: 400 Diesel purge procedure posted by John_400Q on May 15, 2009 at 08:43:50:
Well...maybe I got lucky with a 450...but I did just what you did. Then I cracked the injector lines at the injectors and started it on gas. I moved the throttle just a couple of notches and waited to see the diesel come out of the lines at the injectors. I left it running and started tighting injector lines. When I saw some smoke I hit the compression release lever and she fired.
Don't know if that is the right way...but it worked for me.
