400 Diesel purge procedure
Posted by John_400Q on May 15, 2009 at 08:43:50 from (12.165.170.2):
Could someone provide me the procedure to purge the air from the diesel side of a 400 diesel. I have a tractor that has been sitting a few years. I was able to clean the varnish from the gasoline side. I was able to clean the sediment bowl on the diesel side and purge it with the valve at the top. I was able to open the drains on both pirmary and auxillary filters and open the vents on both. The Auxillary filter purged and dumped diesel out the top, but the primary did not. I also want to drain and refill the injection pump. I see the drain at the bottom, where do I check the fill level after I refill. Thanks, John
