CaseIH 885 3ph question
Posted by PhilcaseinWPA on May 15, 2009 at 11:02:08 from (71.162.23.179):
The 3ph on my 885 does not seem to lift high enough. If i bump the remote valve the 3ph will raise a little more but I can still lift the arms a few inches. I was told there should be some play but this seems to be too much. It become a problem with the plow because by the time I adjust the top link and draft so the plow rides level and all bottoms go in even the hitch barely lifts the 3rd bottom off the ground and I get a lot of scalping during turns and transport. Does not lift the 3ph corn planter enough either. One other thing if the arms are up while the tractor is off they drift down. Any ideas?
Phil
