Hi we had same problem with our 684. Solution was to shorten the left lift link. The yoke part of the lift link screws into a nut on the lower lift link. By removing one end of the lift link and turning it in proper direction the lift link will be shortened. Be Careful not to shorten it to much or the upper lift link will protrude thru the bottom and bind on the 3pt arm when lowered all the way. The right lift arm can then be adjusted with levelling crank. Again be careful that the threaded part of lift arm dose not contact 3pt lift arm. We actually shortened the lift arm by cutting 3/4" off the bottom on both sides. Downside is the 3pt hitch will not lower to the ground as much but this is not a problem for most implements.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
