Re: M clutch Problem????????
Posted by Janicholson on May 15, 2009 at 18:32:32 from (66.173.50.58):
In Reply to: M clutch Problem???????? posted by Trapman on May 15, 2009 at 17:48:45:
Check the free play first. With your hand (not running, and blocked if not flat ground) push on the clutch pedal. It should move easily for about an inch from the platform contact point where it rests when your foot is off of it. If it pushes pretty hard immediately, adjust the rod/clevis to have that inch of free play. Now try it normally to see if it works correctly if not, the clutch will probably need to be replaced. It can be done without splitting the tractor from underneath. there are many posts on this sight (search For box) to get into the replacement. A manual is also a good idea (available here on the top left) JimN
