Posted by paul smta on May 16, 2009 at 12:56:27 from (68.117.10.58):
There is a resistor block between the 12 volt power source and coil reducing the voltage to 6volts I checked this with a meter.My question is this a 6 volt coil? Can I elimate the resistor block and run 12 volts thru the existing coil or do I need to up grade to a 12 volt coil,to the best of my knowelge this tractor came from the factory with the option of a 12 volt system.I am running a petronix pointless ingition and autolite 388 plugs gaped at .032 but the color reading after 1 year of use indicates not enough fire in the wire,this tractor is used very little and not worked hard.Any input thanks.Paul
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
