Re: smta coil
Posted by pete 23 on May 16, 2009 at 19:13:19 from (173.87.14.132):
In Reply to: smta coil posted by paul smta on May 16, 2009 at 12:56:27:
Also being one of them older than dirt guys, I would like to see the 12 volt option in black and white, for a gasoline smta, and like John said, use the ohm meter to see if you have a 12 or 6 volt coil, I have run into conversions where people put on a 12 volt coil and also the ballast resistor, which results in low coil output.
