886 with screaming transmission and no hyd power.
Posted by TOR AT NW FARM on May 16, 2009 at 14:19:32 from (81.230.241.12):
HI
I got a problem with an 886 that I canīt figure out. The tractor screams in the transmission.
If itīs cold or the fluid has been drained it takes about a minute for it to begin making noice, but if I shut it down and then start it again it istantly starts screaming. I have changed both hyd pumps, filter and fluid and yes I have used Hytran oil. It can lift the 3 point but really slow and it also turns the pto but also really slow.
The GEAR that DRIVES the PUMP can be moved by hand though the cover, (the slines is ok) THAT CANT BE NORMAL?
Any ideas, something must be broken where the PTO shat gets itīs power?
Please you more experiensed guys.
