Re: 886 with screaming transmission and no hyd power.
Posted by the tractor vet on May 16, 2009 at 14:32:59 from (76.212.227.78):
In Reply to: 886 with screaming transmission and no hyd power. posted by TOR AT NW FARM on May 16, 2009 at 14:19:32:
Well since i can not hear this tractor and see what sound it is really making and to see if the PTO will pull a load i am thinking that you have a hyd. problem now depending on year of you 886 it may have the open center system or it may have the closed system and if it is the later system then i am not going to be able to help ya as i do not have the rest of the equipment to run the tests on the PFC system and you probably are not close to me
SO YOU MAY BE BETTER OFF TO LET A DEALER LOOK IT OVER.
