Posted by billyar on May 16, 2009 at 17:34:49 from (99.28.36.141):
In Reply to: 5088 transmission posted by Craig Powell on May 15, 2009 at 17:35:30:
Ck all grounds there is a bolt under the right front of the cab. There also a plug in the wiring harness on right side at back of engine. electric connections even low batterys will stop 50 series tractors put over 10000hrs each on 4 0f them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
