5088 transmission
Posted by Craig Powell on May 15, 2009 at 17:35:30 from (24.72.48.111):
I just bought an IH 5088 with 4800 hr. The drawbar is like new and I hoped that it hadn't worked too hard and the transmission would last.(it had a loader before I got it) I pull 24 feet of discer and yesterday when I would stop, sometimes it wouldn't go again in any gear or range. I would try several times and then it would go. When it was going, shifting between Hi/Lo had no effect.Then it stopped pulling completely while I was going down the field.I changed 2 canister filters and a spin-on filter on the trans/hyd. It still doesn't go at all, but I thought maybe the fact that the problem was intermittent at first meant the splines were not torn out of the clutch pack. If anyone has any suggestions, I would really appreciate it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
