Re: Cub with Voltage to lights but they won't work!!!!!!
Posted by IAGary on May 17, 2009 at 03:29:34 from (199.120.96.231):
In Reply to: Cub with Voltage to lights but they won't work!!!!!! posted by Paul Durbin on May 16, 2009 at 20:44:25:
Remember when you hook up the lights that you may have positive ground.
Did you try reversing the wires?
Most lights are grounded to the frame so if you hook them up backwards they will not work.
The reason it will work with the lantern battery is, that battery is not grounded to the frame of your tractor.
I may be all wet if you have already tried to switch the wires around and the problem still exists.
Gary
