Re: Cub with Voltage to lights but they won't work!!!!!!
Posted by teddy52food on May 17, 2009 at 05:39:31 from (209.237.111.169):
In Reply to: Re: Cub with Voltage to lights but they won't work!!!!!! posted by IAGary on May 17, 2009 at 03:29:34:
It makes no differance which way the current flows through the bulb. They will burn either way. Check for bad grounds also.
