Re: Need Basic Advice on Packings-F20 Regular
Posted by BruceS. on May 17, 2009 at 04:48:11 from (76.15.47.42):
In Reply to: Need Basic Advice on Packings-F20 Regular posted by Loren in Iowa on May 14, 2009 at 19:06:29:
I've had the best luck by cutting rings or donuts. Cut the ring on a slant, not straight up and down and stagger the rings. Another approach is to use teflon pump packing instead of the graphite packing. You can tighten this up quite a bit without its running hot.
