Re: 1066 Hydraulic Problems
Posted by Welding man on May 17, 2009 at 15:24:59 from (65.216.168.2):
In Reply to: 1066 Hydraulic Problems posted by Welding man on May 16, 2009 at 13:53:33:
Thanks for the info,will try the oil overfill tomarrow. Hope it works. Will keep you posted.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
