Posted by Welding man on May 16, 2009 at 13:53:33 from (65.216.168.2):
Have a 1066 with gear drive transmission, that is giving me a fit. Was wondering if anyone else has run into this problem.The same pump operates the hydraulics, steering, brakes and TA. When parked on level ground or nose down hill, you can start the engine and everything works. If you park nose uphill or drive up a steep hill nothing works. When everything is working properly the pump pressure checks within specs. The oil and filter has been changed, the pump has been pulled and inspected and new gaskets and o-rings installed.The oil is filled to the correct level. It appears that the pump is sucking air when the nose is up hill, but I cannot find out where. Any help would be greatly appreciated.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
