Re: Farmall A PTO question
Posted by Mike Burns on May 18, 2009 at 13:32:48 from (74.5.56.57):
In Reply to: Re: Farmall A PTO question posted by Red Dave on May 18, 2009 at 11:50:59:
Red Dave,
Thanks for the reply. I am currently using the rear output shaft to drive the top of two pulleys on the belly mower and then another belt on the same double pulley to drive the deck. I have the largest pulley that I can fit on the rear, 9" diameter, and is driving a set of 4 1/2 pulleys for the blades. I need to get the blades spinning faster and, short of putting a 3 inch pulley on the top of the mower deck, would like to know if moving the drive pulley to the side shaft would give me an increase. Any thoughts? Thanks!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
