Re: Farmall A PTO question
Posted by Red Dave on May 18, 2009 at 11:50:59 from (98.235.15.235):
In Reply to: Farmall A PTO question posted by Mike Burns on May 18, 2009 at 11:31:19:
There is only rear PTO. The "side" output shaft is for the belt pulley. The belt pulley does turn at a higher speed than the PTO. I"ve seen them driven both ways. A bigger pulley on the PTO shaft would also turn the mower belt faster.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
