Re: 5088 transmission
Posted by Craig Powell on May 19, 2009 at 11:49:03 from (142.165.93.162):
In Reply to: 5088 transmission posted by Craig Powell on May 15, 2009 at 17:35:30:
Well......the problem was a dead battery. I'm still living in the Case 500 days I guess. But your help was what clued me in so you've saved me a bundle. Thanks a bunch!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
