Re: Re: can't start my TD-9 on gasoline - suggestions?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Skip on April 11, 2000 at 10:15:39 from (208.4.82.34):
In Reply to: Re: can't start my TD-9 on gasoline - suggestions? posted by rodger on April 10, 2000 at 19:44:19:
The little Puffs of smoke may be diesel fuel if the throttle of the diesel is letting to much fuel in it will be very hard to start. Also the needle valve in the carb. may be stuck that has to open every time you switch to "gas". I have a WD9 that starts very well, probably should not have said that!!!!!
Good Luck,Skip
Post A Followup
: Re: Re: Re: can't start my TD-9 on gasoline - suggestions?
