Re: can't start my TD-9 on gasoline - suggestions?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by rodger on April 10, 2000 at 19:44:19 from (63.39.63.226):
In Reply to: can't start my TD-9 on gasoline - suggestions? posted by Loren Pribyl on April 10, 2000 at 19:25:12:
Hello, I have a TD-18, so have some experience. 1)have you had the magneto off? If so, timing may be the problem. It is a challenge to retime, if you've had the magneto off. 2)the magneto has a 'snap' action to it. On my 18 mag, the pawl is on the front of the magneto. Sometimes the pawl doesn't engage and I could crank all day without success. Tapping it lightly and I can hear it engaging and it always starts. 3)You say you have spark---at the plug? 4)Are you sure the fuel line is clear? 5)When attempting to start on gas, press down hard on the 'switchover' lever. Your linkage for the gas to diesel valve may be slightly out of adjustment. I have to hold mine down a bit. 6)What do your plugs look like? Are they clean? 7)Double check the points and the grounding screw which is connected with a wire to the end of the intake manifold, where a limit switch grounds out the system, if the air baffles aren't flipped in the proper direction. If you have spark, this probably isn't the case, although you may want to confirm that these intake dampers are opening--I think you just need to make sure damper shaft rotates when you flip the compression lever. I fought my 18 for several years before deciding that I had a tempermental magneto. I converted it to battery ignition and now, with the exception of the pawl sticking occasionally, it bellers like an old bull, just as easy as you could ever believe.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
