C135 Success, - on to next problems
Posted by tom b in ks on May 20, 2009 at 18:22:00 from (76.7.231.208):
Got the old IH 340 U gas, running pretty good. Rebuilt carb, cleaned up oil bath breather system, new ignition stuff, set gov. linkage, derusted park brake lever, adj, hyd. lever tension.
Does anyone have a fix for the lower rad. hose/tube? They have cobbled up a flex hose with a hose clamp and its leeking badly. Is it salvage yard time?
Is there a place I can print out a wiring diagram? When I turn on switch and at idle, guage shows charge, when I run engine past idle, major discharge.
Have polarized gen. - jumpered gen. to bat. on regulator. No change.
If I get past these two things, she'll be ready to go.
All advice appreciated.
Tom B
