Re: C135 Success, - on to next problems
Posted by CGtractor on May 20, 2009 at 18:46:15 from (69.50.45.97):
In Reply to: C135 Success, - on to next problems posted by tom b in ks on May 20, 2009 at 18:22:00:
On your charging issue it sounds as if the amp gauge may be wired backwards and you have a slight discharge at idle and charging at higher rpms. Put a load thru the gauge by turning on some lights with the engine off. If the gauge shows "charge" it is wired backwards. If it shows discharge you have some other problem.
