Posted by Shawn W on May 25, 2009 at 08:52:31 from (12.109.69.240):
Hello all, Neighbors 1456 was running a silage blower last fall, and pto quit. They said it was really rattling inside rear end. I figure it just needs a new pto clutch put in. But then the story goes on that there is no power steering, and i guess the hyd outlets dont work either. It does start and run, and trans shifts ok, and the torque works. So is this thing junk, or is it a simple fix. I dont have a book for it yet. Might order a I & T shop manual if they desicid to fix it. But wanted to have an idea to tell them first. Its been sitting in the same spot since it broke. It might be for sale also. Whats everybody think its worth. I said $4000 if its an easy fix. Thanks Shawn
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
