Re: 1456 Problems
Posted by trulyred on May 25, 2009 at 10:55:21 from (216.252.3.187):
In Reply to: 1456 Problems posted by Shawn W on May 25, 2009 at 08:52:31:
For the pto and the hydraulics both to quit your problem has to be the splines on the ipto shaft stripped off. That shaft is located in the clutch housing, it is a hollow shaft that splines into the pressure plate. The noise that was heard was the damaged splines catching and then slipping. Your probably looking at a complete clutch replacement.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
