Re: Re: Farmall H low oil pressure problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 11, 2000 at 15:10:48 from (171.208.56.127):
In Reply to: Re: Farmall H low oil pressure problem posted by mj delaney on April 11, 2000 at 11:11:42:
My Super H had a low oil pressure problem after it warmed up. Switched to 15W40 oil and found it maintains higher oil pressure than straight #30 when hot, yet permits reliable starting (on the stock 6 volt system) down to 10 deg and lower. Important to me since the tractor gets used mostly under winter conditions.
Post A Followup
: Re: Re: Re: Farmall H low oil pressure problem
