it is true X-1 means gas only but ( high compression ) there is no real way to tell other then parts on tractor that would give it away , for instance manifold , drain on carb, exta 1 gal. gas tank, the pistons are differant , valves are too in a all fuel engine , gas only didnt have shutters unless ordered that way , also temp gauge will have a mark that engine temp. had to be to switch over to junk fuel, extra hole in the hood for the 1 gal. can , even if you have all these things on your tractor odds are its been overhauled and changed over to a higher compression piston and wont run on junk fuel anymore, i restored my H to run on all - fuel so thats how i know the internal engine parts are differant, you do loose some horsepower doing so but it makes a nice show piece because most cant burn junk fuel anymore because everyone is looking for more power
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
