Help with Cub Lo-Boy Fuel Problems??
Posted by IHMANKY on May 26, 2009 at 15:20:44 from (74.236.250.244):
184 Cub Lo-Boy with the C60 engine, same as all cubs, has the zenith carb. When mowing, tractor runs great on level ground, but when pulling an incline while mowing, tractor soon falters and dies out. Inline fuel filter halfway between tank and carb usually runs about 1/2 full, now starts around 1/4 and then runs dry under load, leading to the choking out. Took filter out of line, still same problem. Take gas line loose from carb, full stream of fuel. Took the carb off, checked jets / needle valve / float, everything seems to be perfect (just rebuilt last fall). It's almost as if it's vapor locked, but heck I even tried it with the gas cap off. Stinkin' thing ran fine last week when I cut with it, get it out of the shed today and it does this junk right off... what is the deal?
